[仪表] 西门子 SIWATOOL V7.1.31.0/SIWAREX_Configurations_Package_04_2014_7MH4138-1...
山海致远 发表于 2018-12-11 12:30:16 | 显示全部楼层 |阅读模式
包含:SIWAREX WP231 1.0.3/1.1.0、SIWAREX WP241 1.0.1、SIWAREX WP321 1.0.0支持windows xp和windows 7,不支持其他操作系统
西门子 SIWATOOL V7.1.35.0下载地址链接:
https://www.eleok.com/thread-120320-1-1.html
Complete TIA Portal sample projects for operating a scale
-     Automatisation software Step7: SIWAREX WP321 with IM 155-6PN STANDARD, CPU
315-2PN/DP and KTP600 BASIC COLOR PN
-     Automatisation software TIA Portal V12 SP1 and V13: SIWAREX WP321 with IM 155-
6PN STANDARD, CPU 1511-1PN and TP700 Comfort HMI
-     Libraries for TIA Portal V12 SP1 and V13 with function block SIWAREX WP321 for
different CPU types and CPU FW releases
HSP_0081_FOR_SIWAREX_WP321 (for TIA Portal V12 SP1 and V13)
Integration of the SIWAREX WP321 module into the TIA Portal V12 and V13 hardware
catalogue
In Step7 Classic V5.5 SP4 the SIWAREX WP321 is directly integrated.
SIWATOOL
Parameter software SIWATOOL V7 for Windows XP / 7
QUICKGUIDE
Short documentation about commissioning and adjusting SIWAREX WP231
FIRMWARE
Latest firmware version for WP321 module: V1.1.0 Firmware can be updated via TIA-Portal.
2  System Requirements
For SIWATOOL_V7: Windows XP / 7
For integration into Step7 Classic: Step7 V5.5 SP4, WinCC flexible 2008 SP3
For SIMATIC-Integration: as of TIA-Portal V12 SP1, WinCC professional
3  Installation of SIWATOOL V7
Close all Windows applications before beginning the installation. In case a virus scanner which prevents carrying out scripts is installed this function must be deactivated during the installation.
In the directory “SIWATOOL_V7_Setup” there is a file SIWATool_V7_Setup.exe. After its execution SIWATOOL V7 can be started as a WINDOWS-application.
volcanol 发表于 2018-12-11 14:45:15 | 显示全部楼层
楼主这个软件是干什么用的呢?
是不是称重的。
 楼主| 山海致远 发表于 2018-12-11 23:06:03 | 显示全部楼层
楼主这个软件是干什么用的呢?
是不是称重的。
是的
肖明磊 发表于 2019-7-9 22:31:53 | 显示全部楼层
打开的时候提示我缺少SWIA-GUI》sdf...请问这个问题怎么解决啊,
我的是win7X64
 楼主| 山海致远 发表于 2019-7-10 00:41:33 | 显示全部楼层
我的是win7X64
使用管理员的权限运行安装文件,我自己安装测试了一下没有问题的。再就是安装文件的路径和安装的目标路径里面不能有任何中文。还有要注意电脑里不能之前安装过任何版本的sql server
肖明磊 发表于 2019-7-10 18:45:18 | 显示全部楼层
谢谢!
还是没有成功勒,我用管理员身份运行,还是提示缺少SIWA-GUI.sdf。
之前安装过,如何卸载了,再一次以管理员身份安装,对您说的sql server有影响吗?
 楼主| 山海致远 发表于 2019-7-10 19:35:03 | 显示全部楼层
谢谢!
之前安装过,如何卸载了,再一 ...
如果电脑上装了sql server这个软件会跟这个siwatool包含安装组件SQL Server Compact Edition冲突,当然如果电脑上没有sql server也有可能出现你说的这个问题,只要系统环境跟西门子带的这个组件冲突,那些sdf文件就会缺失,即便是不缺失也会因为SQL Sever Compact Edition没有正确安装而加载这个sdf文件。siwatool的配置信息都是用sdf文件储存的,sdf文件没有或者SQL Sever Compact Edition引擎没有正确安装都会提示这个的。西门子软件的兼容性就这么回事吧。建议在vmware上用原版iso镜像安装操作系统,在里面安装siwatool测试一下吧。注意千万不要用任何ghost版本,尤其是什么纯净版ghost版本。
leihawk 发表于 2019-7-18 18:00:35 | 显示全部楼层
软件和称重模块是通过485链接么?
superttl 发表于 2019-9-20 20:24:17 | 显示全部楼层
- Exception                                        -
System.NullReferenceException: 未将对象引用设置到对象的实例。
   在 System.Windows.Forms.DataGridViewBand.set_Thickness(Int32 value)
   在 SIWATOOL.GUI.Forms.frmMessage.AttachDataSource()
   在 SIWATOOL.GUI.Forms.frmMessage..ctor(IDeviceFirmwareDB curDeviceFirmwareDB, IErrorMessageFrame message)
   在 SIWATOOL.GUI.Forms.frmMain.get_Message()
   在 SIWATOOL.GUI.Forms.frmMain.ShowHideMessage()
   在 SIWATOOL.GUI.Forms.frmMain..ctor(IDeviceFirmwareDB devFirmDB)
   在 SIWATOOL.Program.Main(String[] args)
 楼主| 山海致远 发表于 2019-9-21 00:30:34 | 显示全部楼层
- Exception                                  ...
这个异常代码很显然是程序界面调用数据出现了异常导致。原因:你现在操作系统里的软件环境兼容性冲突原因,SIWATOOL安装包里的SQL Sever Compact Edition引擎没有正确安装或者这个组件没有有效运行都会提示这个的。西门子软件的兼容性就这么回事吧。
解决方法:建议在vmware上用原版iso镜像安装操作系统,在里面安装siwatool测试一下吧。注意千万不要用任何ghost版本,尤其是什么纯净版ghost版本。仔细看看上面的回帖也是类似的问题。
GMT+8, 2024-4-20 12:14
© 2001-2024 Discuz! Team.
